TwinTurbo.NET: Nissan 300ZX forum - i have had 3 with input shaft or needle bearing noise
ztunerz
on June 04, 2018 at 12:44 PM
The '98 transmission is fine if you don't abuse them. (n/m)
posted by Bernie (NoVA)
on June 02, 2018 at 04:21 PM
in less than 500 miles. driven lightly and switched to quality oil (motul quickly). Replaced by Nissan but I thing build quality is suspect. All shifted like butter though.
Formerly yellowzxtt
Blown transmission... options?
blackomega
19:51:27 06/01/18
Re: Blown transmission... options?
KeepinitClassy
20:08:49 06/01/18
ouikikazz
20:31:57 06/01/18
JWT makes a 350Z 6 speed adapter kit
Hiratsuka0689 (ATL)
07:09:57 06/02/18
They dont sell it (n/m)
16:21:39 06/02/18
JWT stopped making it or what?! (n/m)
blackomega
17:48:56 06/02/18
Also the description sounds complicated (n/m)
blackomega
17:55:37 06/02/18
The 350Z manual trans ratios are not the most
JMartz
07:16:58 06/02/18
16:21:21 06/02/18
i have had 3 with input shaft or needle bearing noise -
ztunerz
12:44:25 06/04/18
I use Nissan oil in them for at least the first 5k miles. (n/m)
09:00:03 06/05/18
For just one guy that's a LOT! Thanks for posting, Harry. (n/m)
OverZealous (CT)
20:18:28 06/05/18
I assume he means customer cars not his personal vehicle. (n/m)
21:27:45 06/05/18
By the numbers for Z32; Z33; and T56....
Gordo NA2LS Daytona
17:02:28 06/02/18
Why does the '98 spec leave much to be desired? (n/m)
ForceFedTT
18:00:41 06/02/18
Yeah what's wrong with the 98 spec?
blackomega
18:09:24 06/02/18
Except for a lack of a better overdrive ratio, $1800 for a
Gordo NA2LS Daytona
18:43:01 06/02/18
Truth. (n/m)
09:21:16 06/03/18
Re: Except for a lack of a better overdrive ratio, $1800 for a
ouikikazz
11:34:11 06/05/18
So what do I do yall? (n/m)
blackomega
17:50:04 06/02/18
get another z32 tranny (n/m)
Kvert
18:10:47 06/02/18
PAR or PPG headsets?
MixManMash
21:10:45 06/02/18
Straight cut gears are too loud for the street
ZXoltan
08:21:52 06/03/18
IIRC, PAR or PPG does offer helical gears. (n/m)
MixManMash
09:20:13 06/03/18
seriously??
11:10:25 06/03/18
[like] (n/m)
16:08:55 06/03/18
Exactly! (n/m)
Musashi Sword
06:55:09 06/04/18
you astound us with your logic (n/m)
wh0sjeff
07:55:32 06/04/18
i'm sure some will disagree but adding another gear
wh0sjeff
07:40:21 06/03/18
Another tranny option for you
ZXoltan
08:24:21 06/03/18
Are you sure that will fit the z32? (n/m)
ConVerTT
09:47:18 06/03/18
watch out for the input shaft (n/m)
ctheobal
10:52:28 06/03/18
